Auto connecting
home99
Auto connecting
I currently have a Binatone ADSL 500 and have it setup to connect automatically (as soon as I power up). In order to disconnect I use the Modem Login page and simply press the disconnect button.
However it appears it reconnects itself after a few minutes without any instruction from me! Does this mean I have to physically remove the cable from the filter in order to guarantee my connection is disconnected?
I would appreciate any suggestions.
Regards
Dave
[Moderator's note by Chris (Eurotrain4): Topic moved to a more suitable forum]
Fixes: 8
Auto connecting
It is probably reconnecting because something on your PC is trying to connect to the internet - this could be your virus checking looking for updates or any number of other things.
Why do you need to disconnect? ADSL is designed to be left connected continuously.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
home99
Auto connecting
I thought perhaps that whilst playing games a connection is not necessary - infact sometimes a game will attempt to access the internet whilst I am playing if it knows I am connected. Being disconnected avoids this problem.
Also, I like to have as many programs as possible disabled if I am playing a game because it takes up resources. I was under the impression Anti Virus and the like can sometimes interfere with other programs, i.e.games. Perhaps I am misinformed?
hitachi
Auto connecting
Hi
Not on the original topic I know but a handy program to use before gaming is enditall
Cheers
Andy
pcorker
Auto connecting
You could try turning it off by the icon in the system tray or, in Network connections, by right clicking the local area connection)
You need to go back to that local area connection to turn it back on. (Not the Binatone icon)
That's with Windows XP.
Proclus
Auto connecting
I have an BINATONE ADSL 500 and i have XP PRO and if i disconnect my adsl it NEVER reconnects on its own i would say that you have got some sort of virus or adware/spyware installed on your system that is trying to use the Internet.
home99
Auto connecting
I have done a thorough check for Ad-aware/virus using numerous software and cant find any problems.
For the life of me I cant understand why it is happening. Sad
pcorker
Auto connecting
I certainly noticed this behaviour in the past. It does not "seem" to happen at present. Maybe it was when I was back on Win98SE and the change to XP fixed it. All of which begs the question... what OS are you on...?
home99
Auto connecting
I am on XP Home SP 2.
pcorker
Auto connecting
That's one theory out of the window then!
Anything in run/msconfig Startup that could be cheekily opening it up? Eg an updater?
Sadly, I don't know what fixed it on my machine as it was only a minor annoyance! Cry
pcorker
Auto connecting
PS ... though I do notice that if the Binatone Login page is set to "Disconnected" then Outlook Express (via AVG anti-virus, in my case) will still download messages if it's "Connect even when working offline" is selected - even though the Binatone Login page continues to read "Disconnected"
home99
Auto connecting
Cheers for that pcorker,
I will have a look at Outlook Express tonight.
Coincidentally I too have AVG Anti Virus.....mmm.... :idea:
