Auto connect possible?
I have just come over to plusnet from NTL and with that it was always "on" so I didnt need to connect on PC start up. I have the Voyager 105 modem and I cant find an option to auto connect. Can I configure it to do that? Its annoying me with my antivirus, MSN and steam which all flas warnings up saying they cant connect etc Evil :shock:
cheers, planning on getting one anyway once my girlfriend brings her laptop down. no short term fix though is there?
Well, one thing I used to do was drag the dial-up connection icon into the startup folder. If the modem is running promptly at start-up it will dial the connection.
Oh, and make sure to remove 'Prompt for username and password',
cheers Cheesy
