Authentication problems?
Hi, i've been unable to connect to plus since around 10pm last night, i get a '421 remote computer cannot respond' or something along the lines, On the adsl dialer status it keeps going through the 'verifying username and password' stage.... i heard theres authentication issues but they're resolved now. Any idea if i'm at fault or whether it'll be back on? :?
The euthentication problems that PlusNet had where well before that time last night.
The best thing you can do, is to reset all your computer equipment, make sure all plugs are seated correctly, and try again.
If this fails, raise it to support as a fault.
Yeah i guessed that, and i've done all the resets (modems cables pc..)
It just suddenly disconnected while i was online last night and i haven't been able to get back on since.
I plugged it all into the spare lappy and i get the same. Sad
