At 4.00pm every day:
Hi, at 4.00pm every day my broadband goes from a nice download speed of 500kps to a silly 15kps until the evening between 10pm & 11pm. Is there any particular reason for this? It happens without fail every day!
Midville
Have you got any local electrical items on a timer? These can/could cause problems, its a bit early for street lighting.......
Which product are you on and have you checked if you've exceeded your usage allowance?
Plusnet Staff
Plusnet Staff
Looks like you've hit your usage limit, take a look at the following page:
http://www.plus.net/support/broadband/products/archive/bb_plus.shtml
You can check your usage using View My Usage under Connection Settings on the left.
You might want to look at upgrading to one of the new Broadband Your Way accounts which you'd probably find more suitable.
Ok, thanks for that, i'm confused... I thought I was on a 40gb download limit per month, not 4gb. Can you let me know what product I am currently subscribed to! Thanks
Plusnet Staff
Plusnet Staff
Fixes: 159
You are on Broadband Plus, the link Dave provided should take you to the specifics of this account. BB+ gets 4GB at peak times , these are 4pm-midnight.
 Chris Parr
 Plusnet Staff
