Are PN still having probs with the DNS
Hi just wondering if they are still having this prob I am having probs loading webpages some time there ok and other times I get cannot finfd page or the page does not load proper any one else having this prob Huh
Just add I have tried 2 browsers I.E and Firefox with the same prob
I'm not aware of any and it's pretty quite on ADSLguide so this may be a local issue for you.
The 'problem' servers before were 212.159.13.49 & .50 so try manually configuring your router or windows to use 212.159.6.9 & .10 to see if it makes any difference.
They are the 2 I have I will try the other 2 see what happens thanks for that Wink
