Anyone know how to check router MTU settings?
I have a USR 9105 router and want to check and possibly change the MTU settings. Anyone know how?
Cheers
craigbrass
Hello,
From what I can find, you cannot manually set the MTU on that router. I found :-
The MTU i believe is set automatically and besides, if you use PPPoA then you shouldn't set the MTU to 1500 (which is LAN specific). The usual MTU for PPPoA is 1492 (not even 1496).
from http://forum.emule-project.net/index.php?showtopic=39030&view=findpost&p=339297
Best Regards,
Craig Brass
cheers
but i dont want to set it to 1500 , i wanted to set both my pc and router to 1492.
You can change it,
The article you want is here CLI Settings
here is the commands that you need, extracted from this link
IFCONFIG
NAME
ifconfig – configure a network interface
SYNOPSIS
ifconfig [interface] ifconfig interface [aftype] options | address ...
mtu N
This parameter sets the Maximum Transfer Unit (MTU) of an interface.
Personally I'd try a lower MTU e.g 1478
You can change it,
IFCONFIG
NAME
SYNOPSIS
mtu N
How do you use this please?
I don't totally know, because I don't have that model of router, however I know it can be done.
The router this is for, has a command line entry window/option and you can enter the commands in there.
