Anyone got a 3com Wireless? How do I open ports?
benskia
Hi.
I'm trying to get some decent speeds out of torrent traffic, but can only master around 6kbps in Azureus.
The program keeps complaining that I dont have port 6881 open for UDP.
I've logged onto the router/firewall. Accessed the "Special Applications" page and enabled trigger port 6881 with trigger type UDP on public port 6881 type UDP.
Is that right, or should I be changing something else too? Because even when I do that, it still says NAT error in the port test in Azureus.
Thanks.
1 REPLY
You dont give a model for the router so we cant help you. If you look at
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
It gives clear instruction for forwarding ports and how to setup Azureus
Your pc must have a static ip or it wont work
