Anyone getting drop outs of ADSL
mike001
only my synk light keep going out and I get disconected about every 10-20 minits
Have you been upgraded to something thats just a bit too much for your line :?
mike001
Um no
Well not unless thay have just upgraded me to 4-8 megs :-)
between 12:30am and 8am My adsl synk light kept going out with means some one in the house was pulling the phone jack out he wall which is not the case
It could have been BT doing some work on the exchange but do thay work at that time of night....if not then some thing was happening at plusnet
Or maybe my router is about to pack up..I will have to keep an eye on it today and see what happens
If there is anyone out there that could kindy look at ther connection logs and see if thay had the same thing happening would be nice
Sync light is nothing to do with PlusNet. When its lit it just shows that you are connected ADSL wise to your local telephone exchange.
So if it keeps going out then its a problem between you and the exchange.
Could be router or line thats causing it :?
mike001
Do BT work at night ?
Only I just found this
http://usertools.plus.net/exchanges/?exchange=Ryde&exact=858&plugin=upgrade
Seam ok now, Better even ?
LiamM
Indeed a lot of work and maintenance is done overnight, and this could have been your problem.
mike001
Dam it just drop conection again...synk light out again ?
mike001
Still getting drop outs 2-3 time a night and same in the day ?
Have you checked your line stats on the router? Look for your SNR value then do a quick search for the gazillion posts of similar nature on this very forum. Might help, might not but will at least give you an idea if your line is a bit iffy.
