Anyone else unable to connect?
Phantom_Flan_Fl
Temporary glitch??
Back on OK now. Smiley
Phantom_Flan_Fl
Getting 'Invalid username or password.'
Had to connect through the 0845 number.
Nothing on the status page. :?
Jon
I have just checked your RADIUS logs and they say you're using the wrong password.
Can you rectify this and retry?
Regards,
Phantom_Flan_Fl
My password for my ADSL and 0845 are the same.
I'd rebooted twice and put the password in manually to no avail.
Seems OK now though.
At around 1am today I was disconnected and couldn't connect. It was veryfying the username and password but was timing out. I tried for 40min but gave up and went to bed. Set it to retry connect and eventually it did at some point.
