Anyone else having problems?
magicofthemind
My 7.6 Mbps connection dropped out a short while ago and now I can only connect at 288 Kbps.
James
Do you know what speed you are actually connecting at? By this I don't mean what speed you are getting. If you are actually connecting at that speed, I fully recommend that you restart your router/computer.
magicofthemind
Thanks, James. Rebooting the PC has taken me back to a 7.6 Mbps connection speed.
