Anybody using a Billion BIPAC-702AE PCI ADSL Modem?
I have set it up but it just would not allow me to log onto my PlusNet account.
It does see the ADSL line stating downstream being 2M etc but just would not log on sating that the remote terminal does not respond.
I used PPPoA driver and set the modem as following:
ADSL Line type:T1.413
( Choices are : G.LITE, G.DMT, T1.413, Multi Mode, Modem Default, Driver Default, CMV File )
PVC_VCI=32 PVC_VPI=0
Server type=non-HDLC ( choices are Default, HDLC and non-HDLC )
Protocol:RFC2346 NULL ( choices are RFC2346 NULL and RFC2346 LLC )
Modem Setting within Dialup Networking has ISDN 64K digital circuit handshake unchecked
Please kindly provide me the right setting info.
:?: Thanks and best regards
oliverb
I'm fairly sure the ADSL type should be G.DMT
VPI:0 VCI:38
Thanks for info !!Smiley Got it to work because of your pointer.
ADSL Line type=G.DMT,
PVC_VCI=38 PVC_VPI=0
TCP/IP PPP settings all checked
Thanks once again.
Best regards
