Anti Virus causing problems
I'm running XP Pro and using a PCI Conexant ADSL modem at the moment. However, if I have any anti-virus software installed, my ADSL line drops and reconnects frequently - very annoying!! I've used both PC-cillin & McAfee and they both cause problems
Has anyone else suffered this problem? Or has any idea how to fix it?? Any help would be much appreciated
try Norton.. but other than that it must be a conflict between ur drivers for teh modem and the PC or does the line drop? not the connex btween u and ur modem?
glyndev
I use a Conexant Hasbani router with no problems at all.
I have always used AVG anti virus and have never had any problems with it interfereing wirh any other programs or hardware.
As well as the comercial version they also have a FREE version available.
