Another slow broadband query
I 'upgraded' my broadband speed, it was at a pretty consistent 2mb, following the upgrade it went up to 6mb :lol: it dipped and rose for the next 10 days until it settled at 1.5. Cry
Have launched the broadband investigation thing, have done the bt speedchecker but I am still waiting for the customer service department to sort this out, does anyone know how long this is likely to take as I started this procedure on Monday and there has yet to be any improvement in the service Cry
How are you measuring your speeds - and at what times of day?
Used the speedtester.bt.com, in morning, afternoon and evening. States IP profile for line is 6500kbps.
Have also used speedtest.net and speedtest.bbmax ,similar results with them, and I pay for platium.
So would I be right in guessing that your modem is sync'ing at 7392Kbps (7.3 or 7.4Mbps), which would give you a maximum "theoretical" throughput of 6.5Mbps data?
Your previous "pretty consistent 2Mb" - was that "data" or "synch speed?"
To be honest - 1.5Mbps data rate shouldn't be considered at all bad during peak periods. Quite a few users are suffering well under 100Kbps in recent days (weeks, or even months for some).
If at all possible, do a speed test at about 1 A.M. - and if you get significantly faster rates, then that would suggest that the 1.5Mbps is a result of contention/congestion and traffic management.
You say you "pay for platinum" - what do you mean by that? I didn't think anyone can chose their own traffic management prioritisation (and Platinum currently isn't even in use as of yet, according to PN's traffic management information).
Yes you guessed correctly re modem ect.
The 2 was 2 mbps - latency 78, if that helps
As re platium I was being thick and harking back to aol, but I do expect better paying 21.99 per month. Exchange is green, thinking back the higher speeds were really throughout the day including the 'peak' times. Will try a speed test in the early hours.
Thanks for your input, def wiser than me Wink
