Annoying lag at night time
I've never really had any problems with plusnet at all but the last two evenings its been like this
Pinging portal.plus.net [212.159.8.137] with 32 bytes of dat
Reply from 212.159.8.137: bytes=32 time=140ms TTL=249
Reply from 212.159.8.137: bytes=32 time=146ms TTL=249
Reply from 212.159.8.137: bytes=32 time=141ms TTL=249
Reply from 212.159.8.137: bytes=32 time=143ms TTL=249
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 140ms, Maximum = 146ms, Average = 142ms
What could be causing this kind of lag?
It only seems to happen after about 7p.m.
E:\Documents and Settings\Craig>tracert www.plusnet.co.uk
Tracing route to www.plusnet.co.uk [212.159.8.137]
over a maximum of 30 hops:
1 * * * Request timed out.
2 147 ms 146 ms 143 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 122 ms 121 ms 121 ms gi1-2.801.pth-gw3.plus.net [84.92.2.6]
4 129 ms 154 ms 131 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 137 ms 143 ms 143 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 142 ms 147 ms 133 ms vlan18.sec.ptb-gw4.plus.net [195.166.129.131]
7 120 ms 113 ms 119 ms if2.ptb-al1.plus.net [195.166.129.39]
8 114 ms 113 ms 112 ms portal.plus.net [212.159.8.137]
what would cause that initial timeout?? Am I usin the wrong dns?
Stoko
I have had exactly the same thing - have raised a ticket and am awaiting a response.
See this post on AG.
Looks like there is a problem with pth-ag2 again.
Stoko
Looks like they are replacing some of the cards in it tonight - so hopefully things will be better tomorrow.
