Annoying disconnections - please help
I use PlusNet ADSL at home, normally the service runs fine, however every now and again it goes through a spell where it will not stay connected for more than 5 minutes, it's doing it at the moment, and it's driving me mad.
I rang support and they told me that the line is stable at their end and that it is showing up up as me deciding to disconnect, so the fault is at my end. I have tried swapping modems, microfilters it makes no difference, it has happened on two different PCs.
Does anyone have any suggestions at all as to what could be causing this?
1 REPLY
Had this problem before and when I was experiencing the disconnection problem, my voice line was really noisy too.. called up BT 105 and the replaced the connection from the main distribution to the main box and some external wire too. Problem solved and I'm getting a good connection till now and no problem for the past three months.
