Andrew Lodge(drivers)
Andrew,
all the A360 drivers are the same,even from Dynamode.
See my post regarding your probs.
If you have power management settings in windows(under usb settings in),untick.
Also your psu is under powered.
200W is a bit low,a new psu of 350w is better.
You could us a powered usb hub as that would not draw too much current and would supply the voltage needed.
