Alternative DNS servers?
octafish
I sometimes get error messages saying that a url I've just been viewing cannot be found and then nothing can be found - with the exception sometimes of PN itself. This is a daily occurence and although I'd like to try a non-PN DNS server. Has anyone any details of any?
Steve
Try PNs alternate DNS servers then:
212.159.6.9
212.159.6.10
you will currently be using:
212.159.13.49
212.159.13.50
Sometimes manually configuring them in reverse can help (primary 13.50 & secondary 13.49) or manually set the first 2 or do as I do and have all 4 configured in windows..
Also some firewalls need them entered as a trusted IP to work reliably i.e. ZoneAlarm.
octafish
Thanks, will try that.
Steve
ps. mu 200 speed is very good - consistently at 1.83 - 1.85 Mbps - just thought I'd mention it.
wheelnut
Other DNS I use as a backup:-
BTYAHOO
213.120.62.97
213.120.62.98
213.120.62.99
213.120.62.100
213.120.62.101
213.120.62.102
213.120.62.103
213.120.62.104
194.72.9.34
194.72.9.38
BULLDOG
212.158.192.2
212.158.192.3
DATANET
80.68.34.6
80.68.34.8
ECLIPSE
212.104.130.65
212.104.130.9
PlusNet
212.159.11.150
212.159.13.150
212.159.13.49
212.159.13.50
212.159.6.9
ZEN
212.23.3.11
212.23.6.35
212.23.8.1
212.23.8.6
octafish
Thanks again.
Steve
LiamM
Didn't realise you could use another ISPs DNS server whilst connected to plusnet and vice versa. Does that work?
wheelnut
It works for me - a DNS is a DNS, PlusNet can't stop you and most ISP's don't block access from outside their network.
csogilvie
Note that 212.159.11.150 and 212.159.13.150 will be removed at the end of the year.
