Alcatel Speed Touch
Alcatel Speed Touch
Ive got an Alcatel Speed Touch PCI modem, when I run the ADSL speed up program, it is not displayed.
Is there a way to change/find out the MTU manually? Im using Windows XP Pro.
Steve
1 REPLY
RE: Alcatel Speed Touch
Hi Steve,
This should put you in the right direction.
http://www.adslguide.org.uk/guide/mtu.asp
Otherwise dowload the DrTCP from the same page
Narg
> Hi,
> Thanks
> Steve
