Alcatel Speed Touch 510
Is there someone out there using Alcatel Speed Touch 510 ethernet router with Plus.Net ADSL service? If yes: any problems with setting it up?
Alexis
RE: Alcatel Speed Touch 510
Yes, I had no real problems with mine. The CD supplied with it by DSLsource contains an INI file already set up for Plusnet, so I just needed to enter my username & password and let the installer do the rest.
The only hitch I had was that my 510 had apparently been preconfigured with a password, meaning I couldn't access it, but the "factory defaults" button on the back sorted that out.
Chris
I have one of these (and use it with Linux). It works fine for me.
If you don't already have an established network, you can just plug in and go. dslsource.co.uk included a CD with some sample ISP configurations (including PlusNet).
I had to edit the sample config, since I had to change the IP address of the router from its default.
Have fun!
Marc
Thanks for your replies... that makes my decision a no-brainer !
