Advice please on: ADSL Modem/Routers
Tiger50
HI
I am migrating from my present isp to plusnet and would like to know if all the adsl modem/routers will work with plusnet, are their any to avoid, are their any that could be recommended.
I have three desktop pcs and two laptops, and would like to go wireless with the laptops and have the option to hard wire the desktop pcs.
Any advice or suggestions would be most welcome.
Many thanks
Ray ( ray@busters.plus.com )
[Moderator note (by acarr) : Removed bold tags from topic. They do not work here, and will only cause your thread to be ignored for attempting tp get more attention than others]
1 REPLY
Yes, all ADSL modem/routers sold in the UK will work with PlusNet.
I would recommend the Netgear DG834G or Linksys WAG54G to connect your PCs together. Both have wireless, 4 port switch, router and ADSL modem built in and also include a SPI firewall.
