Adsl wireless set up
HI
I am new to adsl would like help setting up my system.
iwant to connect between my PC and my telephome splitter
without hard wirering directly,but i don't know what hard ware i
will need or how it should be set up.
the splitter is @ 15m and one floor from my PC,
any help on this problem is wellcome
thanks
1 REPLY
Have a look at this link here for ideas.
You can do it with an all in one modem/router/wireless access point,
at the telephone point and a wireless PCI card connected to
your PC's motherboard or alternatively a USB version, but
I'd recomend PCI. Other options are also discussed.
Alec
