Adsl upgrade
Adsl upgrade
:? Hi does any one know if you upgrade to 1mb from 512k if you need to change your modem I currently use a zoom ethernet external modem :?: thanks Barrie :lol:
1 REPLY
Fixes: 5
Adsl upgrade
There should be no problem using the same modem. You may need to tweak your MTU settings to get maximum speed though. See MTU Tweak for more information.
