Adsl problems
Adsl problems
Hi ime having problems with my adsl again this time it keeps diconnecting every so often.I think its got something to do with me phones as my lines have gone really crackly that bad i cant use the phone.I think i know the problem though i took apart me master phone socket to reveal 2 loose wires a orange one and a black one i was wondering if any of you know where these suposed to go.I dont want have bt out until all else fails miswell give it a good go meself .I better post it quick now before i get cut off so anyhelp will be grateful..... dave Ps it takes about 10 mins to find signal on my modem when i start up
Adsl problems
This wiring guide might be of use.
Adsl problems
thanks it was a wring problem one of the wires had come free so with the help of the guide put it back in the right place thanks again dave
