Adsl Modem / Routers
Voodoo
Hi all
Does anyone have a recomendations on Modem/routers I am just waiting for confirmation of mt ADSL line.
I was looking at getting either the ASUS AAM6000BI or the Speed Touch 510 4-Port ADSL Ethernet Router.
Does anyone have any comments or use any of thes items.
Paul
:bounce:
RE: Adsl Modem / Routers
I beleive there is a serious secuity issue with this one that was listed on Bugtraq. I dunno if Alcatel fixed it wioth a firmware upgrade but basically the flaw meant that someone could connect to it and upload their own firmware to it with no let or hinderance. Sorry I don't have any more info than that.
> Hi all
> Paul
> :bounce:
I've just bought a Dabs AMX-CA61E router, it has four ethernet 10/100 ports and is only £90. See http://www.adslguide.org.uk/hardware/reviews/2002/q1/amx-ca61e.asp for a review.
I'm new to ADSL but it seems to work really well, when I did a speed test it was downloading at 460kb.
Good luck finding something suitable.
Keith
