Additional ip addresses required
Can someone from support please tell me how much it will cost to have an addition external ip address assigned to my connection. I have Business 2000 no-nat.
Thx.
chino
RE: Additional ip addresses required
They should be free..
As far as i can remember all you have to do is request it via the contact us system ...
Support do not post in here all the time so it best to put a message direct to support for this...
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
I did request them but have the horrible feeling that the multiple addresses are given as follows:-
My static address 195.166.166.168, 255.255.255.252
Router Address 195.166.155.169
Firewall address 195.166.155.170
Which gives me three addresses.
Hmmm if this is the +net idea of multiple IP addresses I have been well screwed!
> cUnDaLl
Simon
The 255.255.255.252 subnet mask gives you 1 extra usable address..
In your case
195.166.166.168 - network address (not usable)
195.166.155.169 - normally router
195.166.155.170 - your other host
195.166.155.171 - broadcast address (not usable)
Get this little prog, I find it quite helpful..
ftp://ftp.3com.com/pub/utilbin/win32/3CIPCalc.zip
I thought I would need addresses, but find that using NAT and PAT (port address translation) there is no need (and I feel a bit safer). With PAT on the router you would tell the world that eg your SMTP server is 195.166.155.169 (router), on the router you say that incoming SMTP traffic on port 25 gets routed to eg 10.0.0.10 port 25.
To be honest I found that simpler than trying to figure how to assign 1 ip address to 2 interfaces (pppoa(adsl) and internal ethernet) on my SpeedTouch!
All the best.
