Activation
Activation
Apparently BT state that my order is due tomorrow - is this when my line is activated if the tests are ok?
How long do the tests normally take?
1 REPLY
RE: Activation
Hi there
It depends on how efficent BT wants to be ! Keep a eye on ADSL Tracker.
Also need to wait for ADSL modem - once your line is activated (assuming you are buying your own) - takes 2 FULL working days.
Best of luck.
