Activating ADSL in XP
Ok, so I have ADSL working. My XP PC makes the connection to the ADSL line on startup, but not to my PlusNet account. Is there any way of automating this?
I know I could leave the PC "always on" but for various reasons I don't want to do this.
Can anyone help?
stonechat
RE: Activating ADSL in XP
Well I'm using a router,so that establishes a connection for me. Are you using a router or PCI/USB modem?
Bob
> Can anyone help?
I'm using a PCI modem. Like I said, the modem establishes a connection on startup but then I need to use Network Connections to connect to PlusNet.
I've tried forcing something, e.g. by putting the DUN shortcut in the startup folder but this fails because it tries to connect to PlusNet before the ADSL link is active.
I guess some kind of script may be possible but I'm a bit naff at that sort of thing...
The simplist way of doing it would be to setup in IE all ways dial default connection and then put your email in your startup with it set to check mail every 2mins.
The problem with any script is it may trigger to earley before the services have loaded and fail
I've tried that but it falls over 'cos the ADSL modem is still negotiating a connection when the email software first tries to 'dial' in.
