Accessing my apache server from outside my network
This is probably a simple question but one I can't figure out. Does anyone know how I can find out the IP address to access an apache server running on a PC that is connected to the internet via router?
Do I need to enable a port on the router or change something in the config file for apache?
I'm using the latest version of apache and a Netgear DG814 router. Any help appreceated.
Cheers
I'm not sure what you mean...if you need your IP address, look here www.whatismyip.com
www.whatismyip.com
Actually a little inacurate of your via NAT but winipcfg or ipconfig depending on your flavour of windowz should help you out.
Chris
Got this figure out using a info from a different thread.
Cheers
Admin - please lock/close/removeHuh this thread thanks
