AccessRunner crash(?)
LastRoMan
Hi Guys!
I have Dabs ADSL PCI modem - easy to set up and run - but with one problem. Intermittently if I use "Disconnect" the function subsequently crashes. Indicated by the double conputer monitor icon in the system tray being struck out by a red X (cross).
I then get he error message "Tapisrv caused an error RPCRT4.DLL"
I cannot then subsequently re-connect to the line. To do this I have to Restart my PC.
I have a 450MHz Pentium 3, with 256MB RAM. I connect with PlusNet who I rate.
Can anyone help please?
seero (aka Conrad)
RE: AccessRunner crash(?)
Sounds like the need for an updated driver, or maybe a possible faulty ADSL modem.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
> Hi Guys!
> seero (aka Conrad)
Both files are part of windows, so you might have too reinstall the TCP-IP protocal, if not then try a Repair install of 98
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
@ in #utgames #utchat #uthelp
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
hmm no idea where I got 98 from but if you are using 98-win2k then try reinstalling TCPIP.
But for XP, there is a method to repair TCPIP but is difficult, so maybe better trying a repair install
IRC.UTCHAT.COM
LastRoMan
> IRC.UTCHAT.COM
Good guess Gus,
Or are you psychic.
I have Windows 98 ME. And the .cab files are on the Hard Drive - the GUI was on when I bought the machine.
I am not familiar with a "repair install" will that mess up my Start button, because I have too many programs to want to loose them?
Thanks,
seero (aka Conrad)
> Good guess Gus,
> Or are you psychic.
> Thanks,
> seero (aka Conrad)
By a repair I mean running the windows install again and it will usually just over write the windows files, but leave any applications that have been installed in place.
I say usually, but always backup anything vital. so if your HD is big enough make a partion too hold anything you Cannot risk loosing
LastRoMan
> > Good guess Gus,
> > Or are you psychic.
> > Thanks,
> > seero (aka Conrad)
Thanks for all your help I will go for the Windows Reinstall option when I can fit it in. Thanks again,
Conrad (aka seero)
www.conradroe.co.uk
hi, did anyone have any luck with this fix? i too have the same problem.
