Access to router but no access to internet
I cannot access the internet from my laptop using the wireless router but I can access the internet using other local wireless connections. The signal is a good signal and I have checked everything I can think of including IP addresses, I can't work it out, any ideas?
Hi.
Assuming you have an internet connection.
Can you ping internet sites by name? If not it is a dns problem.
If not a DNS thing it could well be a security issue.
Can you connect to the router through a wired connection and see if the wireless side is activated and also see what security settings there are.
Cheers
Jon
Hi
Disabling your lap top firewall (if any) is also worth a try.
Software updates can cause havoc.
Also have you tried re-running the "set up a wireless connection wizard"
Cheers
Bill
tstaddon
Something else to watch out for - DECT cordless phones. We've found that if one was plugged in, the moment it rang the router fell over.
Changing the router helped us, but worth checking - if you have a cordless phone, try unplugging it from both the phone and the mains, then rebooting the router/modem.
