Access to Plusnet from USA
zebo-the-fat
Is it possible to connect to Plus net from the USA without using long distance dial up? Would it be better to just use an internet cafe to check emails?
LiamM
You can check your Plusnet emails using webmail from any connection, anywhere in the world. Dialing up would certainly be a very expensive way of doing it.
mitchell20
If you have a lap-top with a network card, many US hotels now offer high speed internet in their rooms. You just plug in the nic cable into your nic card and log onto the net.
It will propably cost you a daily fee to use.
I been able to access everything on Plus Net including email when I have used these services.
If high spped interent access is not available in rooms most hotels have business centres with PC's with internet access.
