ATM Connection
KJS
ATM Connection
Here's one for you techno guru's.
Having just recently got asdl + starter pack usb external and installed everything works very well but one very small problem sometimes occurs.
It is sometimes and only sometimes when booting l get the error on the atm network that something is unplugged but dsl status and modem shows that it is connected, also if l do nothing and connect to the internet a second icon appears and everything works ok - but the network atm says it is not working. But if l disable the atm and then re-enable it it all connects fine with no little red crosses through the network connection. :?:
Regards
Keith
1 REPLY
Del
ATM Connection
I also get the same message a lot (a network cable is unplugged)
But as far as I can tell it does not make any difference if it's connected or not
A bit of a puzzler I think :?:
DerekCheesy
