AR11 remote management via the Internet
PhilipEastbourn
Is it possible to remotely configure the AR11 router via the internet?
RE: AR11 remote management via the Internet
Yes, you need to enable remote management in the System option of the Utility menu. Remember to set a username and password in the User profile option of the Basic menu first!
Tim
PhilipEastbourn
> Tim
Thanks Tim
I have tried that, and I can access the router using the outside address (static IP) from the office, but unable to access it from home. I assumed that if I can telnet/http into the external address then I should be able to access from home.
Philip
Philip,
You would normally use the LAN IP address (192.168.8.1 by default) to access it from your home LAN. Why do you want to do use the WAN IP address?
Tim
