AOL / PLusnet IP Addresses
I have been informed by a collegue that AOL are blocking Plusnet IP addresses. Does anyone know if this is true. If so has anyone been able to have the IP address unblocked/removed from AOL server(s) :?:
In what matter are they blocking these ip addresses?
The block you talk of relates to e-mail only.
If you send e-mail to AOL using a server you host on your computer, it will fail. Only mail sent via the +Net smarthost will be allowed through.
This is AOLs proactive approach to cutting down spam, by trying to hold an ISP responsible should bulks come through.
I very much doubt you will get AOL to reverse there dicision. I am currently 7 months in talks with them regarding mail that vanishes when sending to there server through an authorised host.
They can take upto 5 weeks to reply to messages, and that is usualy to say somthing that is leter proven false.
Thanks for the quick reply. It makes perfect sense now.
Cheers
Anthony
Mark_Dowd
Isn't this the firm that refused to accept subscriptions from anyone living in or around Scunthorpe?
