ADSLMax Upgrade Crappy Speeds
I got upgraded to ADSLMax, today is the 18th day since the upgrade and I'm not getting more then 512Kbps, I've carried out various BT Speedtest. Below are the results.
10/12/2006 - 21:29
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 411 kbps
11/12/2006 - 05:23
Actual IP throughput achieved during the test was - 443 kbp
11/12/2006 - 11:10
Actual IP throughput achieved during the test was - 437 kbps
Plus.net says that is acceptable, but before I was get around 17xx -18xxKbps, I'm now not even getting close to 2Mbps. Whats the problem?
I've rebooted my router its and Netgear DG834G. Some advice is appreciated.
Carried out a further two more tests
TEST DATE: 11/12/2006
TEST TIME: 11:10
TEST TIME: 13:10
Actual IP throughput achieved during the test was - 413 kbps
Sad
cranwin
I am no Expert but it looks to me like BT have set your RAS profile to 500 Kbps, as you have had speeds higher than this before then it should be possible to raise your profile, however this is all dependant on line conditions and distance from exchange Etc. Blah Blah BLah, sure you have heard all that before.....
Im appromimately 750meters away from my exchange, anyway to get BT to change my RAS profile? If I opt-out of the ADSLMax programme will I start getting my old 2Mbps speeds?
Have you reported this to PlusNet?
Chilly
Chilly
Yes, they tell me that this is within the recommend specifications set out by BT.
cranwin
You are close enough to your exchange to have a much higher profile, I recently got my profile raised from 500 to 7000Kbps. I raised a ticket with PN and after a lot of battling with them they raised a fault with BT who sorted the profile. however my actual speeds have not improved much so I am still battling with them.....
Coming off MAX and back to a fixed 2000 service will get you back to a 2000Kbps line but will probably cost you a re-grade fee
James got on the case and has put a fault out with BT hope to hear from BT/PN or just see a change is speeds.
How long would this normally take? Cool
cranwin
It took just over 5 days for them to sort it on mine, however I had also made a complaint ot BT Wholsale so I do not know if PN sorted it or BT although PN are claiming credit...... :roll:
All sorted out Cheesy, thanks to all especially James.
