ADSL speed test
ADSL speed test
I get the same problems, i notice in the early morning and late at night between say 11.30pm to 6am it's ok, fairly good.
But at times in afternoon or in the evening when most people are home from work and probably using the net connection the speeds are rubbish, and it take me alot of attempts to logon to the network.
Sometimes my ADSL dectector light starts flashing too, then i get cut offline.. it then goes into trianing mode and i have to wait a while or reboot my pc. Sad
Here is a speed test i did at adslguide.org.uk at 00:12 am hours... speed is fairly good downstream now.
Starting speed test...
Do not use your connection until the test has finished.
Downloaded 32768 bytes in 672ms
Fairly fast connection, trying 524288 bytes.
Downloaded 524288 bytes in 8907ms
Now starting download test
Downloaded 524288 bytes in 8786ms
Estimated downstream speed is 466Kbps.
Uploaded 133120 bytes in 40344ms
Estimated upstream speed is 25Kbps.
Results stored.
>>> Speed: 466Kbps (down), 25Kbps (up) <<<
Test complete.
I'll try and do this test at different times of the day today (Wednesday) as i will be home all day, and i shall pos them here to compare the results of morning, afternoon and night-time use.
Although we are getting alot of problems with ADSL, PlusNet is still the best ISP i have ever been with in every way. just a shame!!
Jason
RE: ADSL speed test
UPDATES:
ADSL Speed TEST: Morning, Afternoon, Evening and Night-time
Modem used D-Link DSL-200 (8 MB capable)
31/07/02 @ 00:12 am
Results stored.
Test complete.
31/07/02 @ 00:58 am
Downloaded 32768 bytes in 688ms
Downloaded 524288 bytes in 8891ms
Downloaded 524288 bytes in 8879ms
Estimated downstream speed is 461Kbps.
Uploaded 133120 bytes in 6312ms
Estimated upstream speed is 164Kbps.
Uploaded 133120 bytes in 8156ms
Overall estimated upstream speed is 145Kbps.
Results stored.
>>> Speed: 461Kbps (down), 145Kbps (up) <<<
Test complete.
Broadband Speed Test Results
Results from your most recent broadband speed test recorded on 31 July 2002 at 00:58:14.
Your Connection
Direction Actual Speed True Speed
Downstream 461 Kbps (57.6 KB/sec) 530 Kbps (inc. overheads)
Upstream 145 Kbps (18.1 KB/sec) 166 Kbps (inc. overheads)
More to come during the night!.
Jason
RE: ADSL speed test
31/07/02 @ 01:21 am
Downloaded 32768 bytes in 656ms
Downloaded 524288 bytes in 8922ms
Downloaded 524288 bytes in 8801ms
Estimated downstream speed is 465Kbps.
Uploaded 133120 bytes in 9688ms
Estimated upstream speed is 107Kbps.
Results stored.
>>> Speed: 465Kbps (down), 107Kbps (up) <<<
Test complete.
Jason
RE: ADSL speed test
31/07/02 @ 01:32 am
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Jason>ping www.plus.net
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=40ms TTL=249
Reply from 212.159.8.137: bytes=32 time=37ms TTL=249
Reply from 212.159.8.137: bytes=32 time=34ms TTL=249
Reply from 212.159.8.137: bytes=32 time=39ms TTL=249
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 34ms, Maximum = 40ms, Average = 37ms
Jason
RE: ADSL speed test
31/07/02 @ 02:57 am
C:\Documents and Settings\Jason>ping -n 10 www.plus.net
Reply from 212.159.8.137: bytes=32 time=36ms TTL=249
Reply from 212.159.8.137: bytes=32 time=35ms TTL=249
Reply from 212.159.8.137: bytes=32 time=38ms TTL=249
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Minimum = 35ms, Maximum = 40ms, Average = 36ms
Jason
RE: ADSL speed test
31/07/02 @ 03:00 am
Downloaded 524288 bytes in 8890ms
Downloaded 524288 bytes in 8910ms
Estimated downstream speed is 459Kbps.
Uploaded 133120 bytes in 7922ms
Estimated upstream speed is 131Kbps.
Uploaded 133120 bytes in 4813ms
Overall estimated upstream speed is 173Kbps.
Results stored.
>>> Speed: 459Kbps (down), 173Kbps (up) <<<
Test complete.
Jason
RE: ADSL speed test
31/07/02 @ 04:10 am
Downloaded 32768 bytes in 657ms
Downloaded 524288 bytes in 8875ms
Downloaded 524288 bytes in 8832ms
Estimated downstream speed is 463Kbps.
Uploaded 133120 bytes in 4610ms
Estimated upstream speed is 225Kbps.
Uploaded 133120 bytes in 4625ms
Overall estimated upstream speed is 224Kbps.
Results stored.
>>> Speed: 463Kbps (down), 224Kbps (up) <<<
Test complete.
Minimum = 34ms, Maximum = 38ms, Average = 35ms
Jason
RE: ADSL speed test
31/07/02 @ 04:40 am
C:\Documents and Settings\Jason>ping -n 10 www.uboot.com
Pinging www.uboot.com [62.99.211.54] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 195.206.65.133: Destination net unreachable.
Request timed out.
Ping statistics for 62.99.211.54:
Packets: Sent = 10, Received = 3, Lost = 7 (70% loss),
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Documents and Settings\Jason>ping -n 10 www.bt.net
Pinging www.bt.net [193.113.211.125] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 193.113.211.125:
Packets: Sent = 10, Received = 0, Lost = 10 (100% loss),
C:\Documents and Settings\Jason>ping -n 10 www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.224.113] with 32 bytes of data:
Reply from 212.58.224.113: bytes=32 time=28ms TTL=250
Reply from 212.58.224.113: bytes=32 time=29ms TTL=250
Reply from 212.58.224.113: bytes=32 time=33ms TTL=250
Reply from 212.58.224.113: bytes=32 time=35ms TTL=250
Reply from 212.58.224.113: bytes=32 time=30ms TTL=250
Reply from 212.58.224.113: bytes=32 time=31ms TTL=250
Ping statistics for 212.58.224.113:
Minimum = 28ms, Maximum = 35ms, Average = 30ms
C:\Documents and Settings\Jason>ping -n 10 www.yahoo.com
Pinging www.yahoo.akadns.net [66.218.71.81] with 32 bytes of data:
Reply from 66.218.71.81: bytes=32 time=169ms TTL=51
Reply from 66.218.71.81: bytes=32 time=170ms TTL=51
Reply from 66.218.71.81: bytes=32 time=174ms TTL=51
Reply from 66.218.71.81: bytes=32 time=184ms TTL=51
Reply from 66.218.71.81: bytes=32 time=177ms TTL=51
Reply from 66.218.71.81: bytes=32 time=167ms TTL=51
Ping statistics for 66.218.71.81:
Minimum = 167ms, Maximum = 184ms, Average = 172ms
C:\Documents and Settings\Jason>ping -n 10 www.musicbrigade.com
Pinging www.musicbrigade.com [213.132.96.100] with 32 bytes of data:
Reply from 213.132.96.100: bytes=32 time=76ms TTL=115
Reply from 213.132.96.100: bytes=32 time=75ms TTL=115
Reply from 213.132.96.100: bytes=32 time=77ms TTL=115
Reply from 213.132.96.100: bytes=32 time=73ms TTL=115
Ping statistics for 213.132.96.100:
Minimum = 73ms, Maximum = 77ms, Average = 75ms
C:\Documents and Settings\Jason>ping -n 10 www.realnetworks.com
Pinging www.realnetworks.com [207.188.7.176] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 207.188.7.176:
C:\Documents and Settings\Jason>ping -n 10 www.force9.co.uk
Pinging portal.f9.net.uk [212.159.8.139] with 32 bytes of data:
Reply from 212.159.8.139: bytes=32 time=36ms TTL=249
Reply from 212.159.8.139: bytes=32 time=34ms TTL=249
Reply from 212.159.8.139: bytes=32 time=37ms TTL=249
Reply from 212.159.8.139: bytes=32 time=35ms TTL=249
Reply from 212.159.8.139: bytes=32 time=39ms TTL=249
Ping statistics for 212.159.8.139:
Minimum = 34ms, Maximum = 39ms, Average = 36ms
Reply from 212.159.8.137: bytes=32 time=33ms TTL=249
Minimum = 33ms, Maximum = 40ms, Average = 35ms
www.uboot.com i'm having trouble accessing this most of today.. hmmmmm
Jason
RE: ADSL speed test
31/07/02 @ 06:18 am
Reply from 212.159.8.137: bytes=32 time=46ms TTL=249
Reply from 212.159.8.137: bytes=32 time=43ms TTL=249
Minimum = 34ms, Maximum = 46ms, Average = 38ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 10, Received = 2, Lost = 8 (80% loss),
Pinging www.bbc.net.uk [212.58.224.121] with 32 bytes of data:
Reply from 212.58.224.121: bytes=32 time=31ms TTL=249
Reply from 212.58.224.121: bytes=32 time=30ms TTL=249
Reply from 212.58.224.121: bytes=32 time=29ms TTL=249
Reply from 212.58.224.121: bytes=32 time=34ms TTL=249
Ping statistics for 212.58.224.121:
Minimum = 29ms, Maximum = 34ms, Average = 31ms
Pinging www.yahoo.akadns.net [66.218.71.86] with 32 bytes of data:
Reply from 66.218.71.86: bytes=32 time=168ms TTL=50
Reply from 66.218.71.86: bytes=32 time=171ms TTL=50
Reply from 66.218.71.86: bytes=32 time=173ms TTL=50
Reply from 66.218.71.86: bytes=32 time=169ms TTL=50
Reply from 66.218.71.86: bytes=32 time=170ms TTL=50
Reply from 66.218.71.86: bytes=32 time=174ms TTL=50
Reply from 66.218.71.86: bytes=32 time=172ms TTL=50
Ping statistics for 66.218.71.86:
Minimum = 168ms, Maximum = 174ms, Average = 170ms
*sighs* ok my shift is over. add ping times to this list at different times of the day if you get time... so we can compare.
I'm logging off......
Jason
RE: ADSL speed test
I tried pinging the same servers this morning
here are my results:
Pinging 212.159.8.137 with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=29ms TTL=249
Reply from 212.159.8.137: bytes=32 time=26ms TTL=249
Reply from 212.159.8.137: bytes=32 time=27ms TTL=249
Minimum = 26ms, Maximum = 29ms, Average = 27ms
Pinging 195.206.65.133 with 32 bytes of data:
Reply from 195.206.65.133: bytes=32 time=40ms
Reply from 195.206.65.133: bytes=32 time=32ms
Reply from 195.206.65.133: bytes=32 time=31ms
Ping statistics for 195.206.65.133:
Minimum = 31ms, Maximum = 40ms, Average = 33ms
Pinging 212.58.224.121 with 32 bytes of data:
Reply from 212.58.224.121: bytes=32 time=28ms
Reply from 212.58.224.121: bytes=32 time=20ms
Minimum = 20ms, Maximum = 28ms, Average = 26ms
RE: ADSL speed test
Where was these speed tests done?
We have used a number of speed tests which have been fine. We have however found that the adslguide speed test reports a lower rate at peak times, we think that the speed test may be being well used and thus a little overloaded.
We always recommend you try a few different speed test to ensure accuracy of the figures.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: ADSL speed test
Just pinged a friend server in america i usually get 60k on it with no probs but now:
Packets: Sent= 10, Received = 9, Lost = 1(10% loss)
Minimum = 103ms, Maximum = 108ms, Average = 94ms
RE: ADSL speed test
here are my tests done with visualroute to the bbc:
Report for 212.58.224.121 [www21.thdo.bbc.co.uk]
Analysis: '212.58.224.121' [www21.thdo.bbc.co.uk] was found in 6 hops (TTL=249). But, problems starting at hop 1 in network "BT-MIDBAND" at 122ms are causing IP packets to be dropped.
Visualroute can be found here:
http://www.visualware.com/visualroute/index.html
RE: ADSL speed test
Thanks for the information. Please see our service status message regarding the ADSL platform.
Kind Regards
Kevin
RE: ADSL speed test
Thanks for the tets.
I'm back at the pc again to carry out more.
Even if ADSLguide's speed test is not exact.. there is still a big problem Keven.
I already have visualroute (i bought a key) a while ago, as it also catches mail spammers and traces just about anything.
I will do some reports from this tool aswell.
The other reports came from my pc connected to PlusNet from 11pm to 6am in the morning.. i was testing it all through the night.
The results are true.
31/07/02 @ 12:44 pm
Reply from 212.159.8.137: bytes=32 time=41ms TTL=249
Minimum = 35ms, Maximum = 43ms, Average = 38ms
More later with VisualRoute Smiley
Jason
