ADSL modem settins
ADSL modem settins
Guys,
Being a cheap-skate ( Smiley ) I have bought a DABS ADSL Conexant modem. However I am slightly concerned as the driver software protocol type doesnt list the ones mentioned in the tech - support pages.
Has anyone used one of these modems succesfully ? (Please don't just say 'yes' - if you have tell me the settings !)
Many thanks in advance
Pat
RE: ADSL modem settins
Hi Pat,
Snap, I have just done the same, e.g. cheap dabs modem, mine is the MegaSpeed ADSL PCI Modem.
Instead of selecting the LAN driver ( as the modem manual says ), I used the WAN driver and that has the RFC1577 protocol ( that Plus.net uses ). This seemed to work and I am now using ADSL ;-).
However I am having a problem when my sky box is plugged in. Any ideas anyone? I solved this so far by unplugging it. I have 1 splitter plugged in and my phone and Sky attached to that.
James
> Guys,
> Pat
I meant the RFC2364 protocol, Point to Point Protocol over ATM.
RE: ADSL modem settings
Same here, but what host name or IP address is required to use RFC2364?
Cheers
Thanks James!
Pat
