ADSL keeps disconnecting
My ADSL connection keeps disconnecting at frequent intervals. It then takes several attempts to reconnect, and within a few minutes it disconnects again. Is this a problem with the modem, the line or the server? It can connect, it just keeps disconnecting again.
Can I ask... do you have an internal modem or a USB modem?
Thomas
I had to change to ANSI-T modulation and all worked fine again, also moved the internal PCI modem to a different slot to make sure, very rarely disconnects now, hope this helps.
:lol: Paul
