ADSL initial setting
AskASQLguru
I'd installed the ADSL modem to my laptop without any problem.
Now when I want to configure ADSL connection on the Alcatel USB modem its asking for Username/pwd/dun entry.
I'm not able to find whats the DUN Entry means.
Can anybody flash light on this issue.
If possible send solution to satyaskj@yahoo.co.uk
TIA
RE: ADSL initial setting
you can put anything in the dun entry I use 0,38
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Customer Support .................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
AskASQLguru
Thanks Kevin
> Kind regards
> Kevin
