ADSL faceplate splitters
Naiad
I've been using a surge protected fourway power strip with phone input/output for my computer equipment.
Now thinking of trying one of these adsl faceplates to see if it makes my connection any more stable, but if I fit one of these and plug the router directly into that via a shielded lead, what do I do about line surge protection?
shellsong
Try this http://www.clarity.it/acatalog/surge_protectors.html -- it's likely to be better designed for ADSL use than the powerstrip one!
If you want to see if an ADSL faceplate will improve your adsl without buying one, then unscrew your existing master socket front, pull off the bottom part and insert your router into the now exposed socket to your right. That's the cleanest signal you'll get without BT messing with your line.
[Note that this will disconnect all extensions, if you have any]
Fixes: 57
You can get BT to RJ11 adapters RJS/BTP at
http://www.solwise.co.uk/telesun.htm
shellsong
The Clarity beast is a high grade surge arrestor with a very high speed gas discharge tube for dealing with surges caused by nearby lightning strikes, it's not just an adaptor!
Slipperymack
Shellsong - check your time of post?
PS -I use a Faceplace bought from ADSL nation - http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=24&products_id=90
shellsong
What's that supposed to mean? :?
Slipperymack
Shellsong -
Just that your "post time" was showing 12.19 when the previous post to yours was 10.40 and mine, which was after yours was posted 10.54 (which was the actual time I posted). Thats all.
Naiad
Thanks everyone; that's me sorted. :-)
shellsong
Shellsong -
The previous post to mine was on the 12th, mine was 19 mins after midnight on the 13th Wink
Slipperymack
Shellsong
Sorry - my mistake!!!!!
shellsong
No probs!
I went with http://www.adslnation.com/products/xte2005.php as i already had a v.1.0 that BTards supplied me with 5 year ago. Improved the SNR pretty good aswell as compared to the other.
