ADSL = e-mail problems
Since upgrading to ADSL I have not been able to send e-mails although I do receive mail. To send mail I have to revert back to my standard telephone line connection. If I try to send an e-mail whilst connected to ADSL I get the message:
[not permitted to relay through 550 - this SMPT sever, smpt.tiscali.co.uk is for the exclusive use of 550 customers of tiscali}? God only knows where the hell ticali comes into this, I have never conneted or used tiscali.
My mail box and domaine registration is with uk2.net
Help!!
RE: ADSL = e-mail problems
I would suggest that your outbound [relay] server needs to be set to PlusNet's SMTP server.
Normally you cannot use a non-connected (i.e. not your currently connected ISP's) server as an outbound / SMTP mail server. This is normally to stop spamming via one or more non connected mail servers.
Try setting your SMTP server to:
relay.plus.net
You can find this under tools > options > sending mail in Eudora and tools > accounts > mail > servers in good ol' Outlook Express.
As to where you got the Tiscali entry from... have you recently re-installed IE / Outlook from a magazine or through the door CD?
Hope this helps!
Chris
/Patiently(!) waiting for ADSL activation...day 19
I get the same problem and I'm using relay.plus.net. Apparently it might have something to do with us having a dynamically assigned address or +net not using reverse DNS mapping.
I've been around the houses with +net on this (not very helpful - trying to fob it off as an issue for me to address with each server that's blocking the email.
michaelandkatie, please state the exact message you receive.
The messages above relate to a different ISP, while you have simply coverted from a dial account (by the sounds of your post)
