ADSL dropouts?
ADSL dropouts?
Is anybody else experiencing ADSL dropouts?
I have had to reconnect 7 times in the last
couple of hours. Service Status says there
are no problems. Is it just me?
RE: ADSL dropouts?
I've not had any problems today.
I am in the Heywood Lancs area if that helps?
chino
RE: ADSL dropouts?
Yeh i have had no problems too,
It usally drops out once every 3 days....
p.s. make sure that OE (outlook express) is not disconnecting as theres an option to allow it to do that, also under most modem/router option there can be an option to disconnect.
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: ADSL dropouts?
Thanks for the feedback. It is still doing it.
The problem only started today since I logged
on after being away for a week.
I haven't changed anything from what used to be
a trouble-free setup.
John:
I'm in West London - don't know if there are
any weather related problems with BT but the
phone line works fine and isn't noisier than
usual.
mR cUnDaLl:
I don't use Outlook Express (try Opera!) but
I've set Sam Spade to ping the PlusNet host
every minute ... clutching at straws.
Cheers,
RE: ADSL dropouts?
Experience several dropouts since I went on to ADSL.
Raised thsi with PlusNET but stillwaiting for feedback
RE: ADSL dropouts?
> Also have dropouts, raised ticket with plusnet got fobbed off raised another that got closed. waste of space.
I'm in Kent
