ADSL connection problem
fistsbs
I have Dynamode PCI modem and i have started to get diconnect.
when i run Black Hawk Down will diconnect and not reconnect to the ADSL.
PC Specs
P4 1.8, 1 GB ram, GeForce Ti 4800se
It could be when you're running something, such as Black Hawk Down, the graphics card is taking a large amount of power, and therefore the motherboard can't supply enough to the modem (so it disconnects).
Do you have any other connection equipment that you could borrow?
fistsbs
I have change the setting on my graphics card and that has fix the problem. Cheesy
