ADSL connection number....
Hi all,
I am in the process of migrating from B.T Plug and Pray 500 Broadband to Plus Net's 2mb Homeworker connection.
My question is, does anyone know what the connection number will be, I have had a look through the Plus Net site but have not seen anything. Will it be the same as B.T's connection number or will it be a new one.
I guess I'm worrying incase the migration goes ahead and then won't be able to connect, no 56k dial up modem on my Comp, just a USB ADSL modem.
Thank you for any help with this matter....
Andy...
You shouldn't need a connection number
You should have an image in your system tray (if you are using a bt modem), in which you open, click connect, and enter your plus net username and password.
It will be different if you are using a router or over anetwork however.
Come back if you need more help.
Steven
Thanx for that Steve... Cheesy
Andy...
Is it working now?Huh
