ADSL and ICS on WinXP...
Anyone else trying this? Have found that I can't get a continuous downstream with ICS turned on, comes in bursts of about 1.5 seconds, then 0 b/s, then normal again, and never reaches the peaks that I get when I turn ICS off.
Any ideas?
Cheers,
Jim
RE: ADSL and ICS on WinXP...
I would reccomend you go and get yourself a copy of Winroute and disable ICS, Let Winroute handle your connection sharing and firewall its incredibly secure and fast.
I initially used ICS under Win2k and was dissapointed that a lot of firewalls have to have their security turned down to support ICS wich i was not happy with.
Winroute provides top notch security and internet sharing and is easy to setup.
Ali
> Ali
More info on Win xp ICS can be found at www.practicallynetworked.com
But yes I to have experienced a bursty connection and will try winroute as I have a copy Ill let you know how it goes !!!!
This is a reminder that you absolutely must disable Windows ICS on your machine before installing Winroute, its all in the Winroute Installation FAQ i believe.
Ali
