ADSL and Cisco Connection Problems
I have recently had adsl installed at home. However, since then i have not been able to connect to our Cisco PIX 515E Vpn. I use Win XP at home and i use a netgear DM602 USB/Ethernet modem. Everything is set up ok (i think) but when i try to connect i get the message 'server not responding' .
If i try connecting using a dial-up connection i connect straight away.
Can anybody help?
Thanks,
Pl
