ADSL & Linux
ADSL & Linux
Hi all,
Was hoping someone out there in plus.net land might know some good resources helping me to set up my linux with ADSL I was thinking drivers and how-to's...
Ta very much
Si
RE: ADSL & Linux
What Linux and modem are you using?
I have just installed my adsl am using a dsl-504 router. I have a windows machine and a Mandrake linux machine connected and can access the internet from both.
In Mandrake I just set up the network with DCHL, with no modem or adsl modem. If I click on the connect to the internet button, the connection is just part of the network.
I have noticed that the adsl connection software in Mandrake uses PPPoe connection profile instead of PPPoA.
I do have one problem and that is seeing the windows machine from linux so that I can remote print. Can anyone help?
I hope this helps
regards
Paul Stear
> Hi all,
> Ta very much
> Si
RE: ADSL & Linux
I have a USB ADSL and a slackware distribution of linux.
I wanted to have that machine running as the gateway for the LAN, there are a few folks on my house wanting internet access, and my only other computer is this laptop, which isn't always on.....
I'd noticed the PPPoe thing.
this is really puzzling, no-one anywhere seems to have a clue....
> Hi,
> I hope this helps
> regards
> Paul Stear
> > Hi all,
> > Ta very much
> > Si
