ADSL = Worse than 56K
Just noticed tonight that everything is downloading really slow, my ping times are worse than a 56k i.e. >300ms to every server.
DUMeter says Average download rate of 3kb/s!
RE: ADSL = Worse than 56K
C:\>ping www.plus.net
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Request timed out.
Reply from 212.159.8.137: bytes=32 time=182ms TTL=249
Reply from 212.159.8.137: bytes=32 time=184ms TTL=249
Request timed out.
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 182ms, Maximum = 184ms, Average = 183ms
Hmm, ADSL problems, AGAIN and AGAIN! Sad
Grimbo
Although Plusnet will deny it, the problems ARE starting again.
If they insist that they have bandwidth to spare, then they need to get their finger out and find the problem, but on a server where many players have 20-30ms pings, mine ranges from 450-500.
I have had these results and have had pings of over 400ms as well.
Reply from 212.159.11.150: bytes=32 time=118ms TTL=248
Request timed out.
Reply from 212.159.11.150: bytes=32 time=190ms TTL=248
Request timed out.
Ping statistics for 212.159.11.150:
Minimum = 118ms, Maximum = 190ms, Average = 77ms
I ask you, how can you even think of using the net with these kind of speeds?
Pinging 212.159.11.150 with 32 bytes of data:
Reply from 212.159.11.150: bytes=32 time=355ms TTL=248
Reply from 212.159.11.150: bytes=32 time=310ms TTL=248
Reply from 212.159.11.150: bytes=32 time=353ms TTL=248
Request timed out.
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 310ms, Maximum = 355ms, Average = 254ms
I thought I would try a SpeedTest at www.adslguide.org
Here are the laughable results:
Starting speed test...
Do not use your connection until the test has finished.
Downloaded 32768 bytes in 4450ms
Very slow connection, trying 65536 bytes.
Downloaded 65536 bytes in 5160ms
Now starting download test
Downloaded 65536 bytes in 15870ms
Estimated downstream speed is 32Kbps.
Uploaded 133120 bytes in 8780ms
Estimated upstream speed is 118Kbps.
Results stored.
>>> Speed: 32Kbps (down), 118Kbps (up) <<<
Test complete.
Your Connection
Direction Actual Speed True Speed
Downstream 32 Kbps (4.0 KB/sec) 36 Kbps (inc. overheads)
Upstream 118 Kbps (14.8 KB/sec) 135 Kbps (inc. overheads)
'Actual Speed' is the amount of useful data that your connection can transmit/receive per second. The 'True Speed' figure includes an approximation of data overheads (non-useful data).
Great Speed tonight ... Not.
And a lack of support answering the posts, I hope that means they are fixing the problem.
It would be even more helpful if the status part of the Customer Support section got updated when these problems come about rather the a day later when everyone has complained in the Discussion Forums.
Angry Angry Angry
In the last hour, things have improved "as if by magic", downloading again at almost 60kb/s and pings to plus.net are between 20ms to 90ms again.
If only we could discuss these problems in 'real-time' with Support in a chat room. Instead I have to make a premature post about a problem that corrects itself somehow Cry
i dont believe it bollox pings, pl is throught he roof, cant dl might aswell get my modem out atleast i would get 5k a sec atm i am on 3k so where is my other 57k gone adn i am sure my upload is naffed aswell....
Support replies are conspiquous by their absense!
Rog
LastRoMan
> Rog
I agree with you all there does seem to be a bit of a log-jam. So I am loathe to go on recommendidng PlusNet ADSL to my friends while PN are experiencing difficulty handling the customers they have - it makes me look as if I don't know what I am talking about!
It is embarrassing to contact them some days.
Conrad (aka seero)
Please see our servicer status posting. This shows eactly whats happening with ADSL.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Have run a series of bandwidth tests this morning and speed is like a yoyo on "speed" one minute, "downers" the next. Not the best annalogy in the world I know but am sure you know what I mean. So problem is certainly not confined to the so called "busy" periods.
So, heres hoping that "fix" to all these problems experienced by so many loyal customers of yours plusnet is completed very soon.
Why oh why did I sign up for a yearHuhHuh?
Yes I have read the status connectivity notices by customer support. They may be doing their best(perhaps not), how are we to know?
