ADSL Trouble
weatherman
ADSL Trouble
:roll:
I have built a new computer. with an ASUS A8V Delux wireless LAN Motherboard, I am using a ZOOM ADSL USB Modem, this works fine on my existing computer but I cannot get a connection through this modem on the new computer.
I am wondering if the wireless LAN component on the new board could be causing the problem, I have been in touch with support and spoken to three separate people who have talked me through the setup procedure but have only suggested I check all my connections, these work ok (as I am sending this from my old computer using the same connection, just changed over the usb plug) has anybody had trouble of this nature if so how did you solve it?
