ADSL Stopped working
Every 3-4 hours my USB modem the Green Stingray thing just drops my adsl connection, both lights go out the icon in windows goes yellow, i have to unplug the modem from the USB port and plug it in again?!? any ideas?Huh
RE: ADSL Stopped working
Mine does the exact same thing I neep help on this please too.
BoneMan
> Mine does the exact same thing I neep help on this please too.<
Guys,
This *may* be a USB power issue. There are suggestions that USB modems are on the limit for amount of power some USB ports can supply; this often seems to be motherboard dependent. I think that if you do a search of the forums on http://www.adslguide.org.uk/, it may be useful. A common (although not cheap) solution is buy a *powered* USB hub and plug your "frog" into that. The "frog" will then take its power from the hub and not your mobo. Perhaps you could get the loan of such a hub to prove the point (or otherwise ;-) ) before you buy one.
BoneMan
Where about are you located in the UK?? just want to see if it's the exchange
